fuel pump not working, fuse or relay?
1990 CHEVROLET SILVERADO
152,000 MILES • V8 • 4WD • AUTOMATIC
REEBENU
pulled tank and tested fuel pump by hooking sending unit straight to battery works fine. will not work when it is plugged into regular wires. traced wires did not see any breaks or bad spots. replaced relay and fuel pump fuse. also the ignition was replaced about 4 months ago. it died a couple of days ago and i checked to see if it was getting fuel but wasnt sprayed starting fluid in th throttle body and it would star but die of course. i also checked the pump before i pulled tank by runnig a wire from battery to the aldl g wire and nothing happened the book said pump was bad. please help dont know what else to do!!!!!!!!!!!!!
Aug 16, 2008 at 4:31 PM
JETSA
  • 117 POSTS
So no fuel sprays from the injectors when its turning over. Do you hear the electric pump turning for approx. 3 seconds when you turn on the key? Reason I ask is the problem may be fuel pump related or fuel injector related. Trying to isolate your problem. Reading your issue again, it sounds like the pump isnt working, but I would need verification of my initial question. If the pump is not turning on, you could get a test light and find the fuel pump relay which is located on the firewall behind a black plastic cover on the passenger side under the hood. Find the gray wire and backprobe it while someone turns on the key. This wire goes directly to the fuel pump.
Here is a guide to help check the fuse and the relay with the location of the fuse and relay in the diagrams below.
and
Check out the diagrams (Below). Please run this test and get back to us.
Aug 16, 2008 at 11:49 PM
REEBENU
there is no power going to fuel pump through harness relay is new could the oil pressure switch be the problem, or maybe even ecm? i was told that it may be a wire from the battery or maybe even the starter is this true??? I need to get this thing on the road to soon. Please help
Aug 17, 2008 at 3:22 AM
CHEVYBOY
so i bought a new one and changed it out. before i bolted my tank back up i turned my truck to the run position and waited till i could hear it. once i heard it i shut it back off and bolted the tank back in. then once i tried it again its not workin. why is this??
Jul 6, 2020 at 4:39 PM (Merged)
  • CERTIFIED EXPERT
  • 110,175 POSTS
Check the wiring near the pump. Check the connectors between wiring harness and pump. Check for bad grounds.
  • CERTIFIED EXPERT
Check the fuel pump connector-it should come on for 2 secs when the fuel pump relay is activated-if not check the relay-
KRISE84
Hi, I was wondering where the fuse, if there is a fuse, for the fuel pump would be located on this vehicle. Could it be a fuseable link? I reclaced the fuel pump relay today because it cost less than ten dollars and that didn't fix anything. I didn't think that was the problem since both parts ohmed basically the same. I know that the fuel pump runs because I hard wired it to find out. My brother replaced it a while back because he thought that it was the problem. He also cut two of the wires that run to the fuel pump and spliced them. He claims that they were bare from rubbing the frame and shorted out. I replaced what he had spliced in with the correct gauge wire and tucked them in their cover to make sure that they can't rub through again. Anyway, because of what he has told me I would guess that the pump was fine all along and that something else, say a fuse, gave out. Anything that you could suggest or tell me would be greatly appreciated. Note: Someone at a local parts store said that it could just have a relay and not a fuse. Is that true? Thanks
BLUELIGHTNIN6
  • CERTIFIED EXPERT
  • 16,542 POSTS
check out the fuel pump oil pressure switch, if it fails then fuel pump will not get power. it is found on teh rear of the engine block near the distributor (4.3L, 5.0L & 5.7L) OR on the left side of engine block under the exhaust manifold (7.4L) .
HIJO DE UN REY
Where is located the oil/fuel pressure switch?
Jul 6, 2020 at 4:40 PM (Merged)
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
If you're referring to the oil pressure sending unit, it will be screwed in next to the oil filter or right above it on the top of the engine where there's an internal oil passage.
ROCK283
Hi, I have a 1986 gmc 4x4 fuel injected 305 i have spark and the fuses are all good it has two tanks it will not pump fuel and it has 147k on it i know right low k but it sat four 5 years I am 44 and i have bin doing cars since i was 14 and ya i don't know, the pump fuel and its bin siting for 5 years and someone stole the alternator i put a new one on can a guy hot wire the fuel pump to see if works, please help.
  • CERTIFIED EXPERT
yes. you can bypass the relay or remove the cover of the relay and connect the points. it should fire up. after 5 years, it may be good maintenance to replace it.
  • CERTIFIED EXPERT
You can apply power to the fuel pump test connector
2CP-ARCHIVES
  • 4,540 POSTS
driving down the road it started sputtering then died. fuel pump relay good. fuel pump runs when jumpered . fuses are good. something is not letting fuel pump to run. Is it the oil pressure switch? can it be reset?
  • CERTIFIED EXPERT
Turn the key On-Do you hear the fuel pump come On? If so check the fuel pressure if its within specs and then comeback with the readings-we start here-
  • CERTIFIED EXPERT
If the fuel pump relay is good then check the computer controlled of the fuel pump relay circuit, computer might not be grounding the relay if the fuel pump is not being activated-the oil pressure switch powers the pump after the engine starts
CHEVYBOY
Hello I replaced my fuel pump and it works, but im still not getting fuel to my motor. Could it be that my fuel filter is clogged?
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
it could be , normally when you replace a pump you do the filter at the same time. the wires in the tank to the pump are very fragile and they may be broken too, if you get the filter off, turn the key on for a brief second an dput the fuel in a jar if it comes out.
Jul 6, 2020 at 4:41 PM (Merged)
  • CERTIFIED EXPERT
Check the fuel pressure if its within specs and check the injector/s if its opening and closing
CHUY775
my 1990 chevy k2500 wont start.Like its not getting fuel replaced the fuel pump but still nothing.Could it be one of the 2 injectors??
JDL
  • CERTIFIED EXPERT
  • 16,098 POSTS
Can you see an injector spary pattern, engine cranking? Use a gage and check fuel pressure. Did you check for voltage and ground at the fuel pump connector, engine cranking?
CHUNKY
1990 Chevy Silverado V8 Two Wheel Drive Automatic
the truck has new fuel pump but i have no power the pumps not coming on and I lost power to my signals could it be a relay because iam not getting power to the pump fuse.(please help)
JDL
  • CERTIFIED EXPERT
  • 16,098 POSTS
If you have a fuel module, the voltage to the fuse may come from the fuel module. My info showed for 5.7 hd only and then said L05 and L19, which I guess is a manufacturer ID designation.
The only location I found for the module, where applicable, is next to the pcm. The wiring colors, brown is ignition feed, Black with white tracer is ground for the module, Tan with white tracer is voltage for the fuse. I don't like trying to follow those spaghetti diagrams, sometimes I lose my circuit.LOL
CHUNKY
could you tell me where the fuel module on this truck is located c1500
JDL
  • CERTIFIED EXPERT
  • 16,098 POSTS
It should be located by or next to the computer. Under the dash, passenger side, behind glove-box cavity.
I gave you the wiring colors for the connector. I'd check the circuits. You didn't list the liter size of your engine?
CHUNKY
thanks for your help its a 5.7 and i checked all the fuses i could find and there all good i noticed if i disconect the fuel relay and bypass the plug it all works but the truck won't turn off with key
CHUNKY
[quote:3ea759bfef="chunky"]1990 Chevy Silverado V8 Two Wheel Drive Automatic
the truck has new fuel pump but i have no power the pumps not coming on and I lost power to my signals could it be a relay because iam not getting power to the pump fuse.(please help)[/quote:3ea759bfef] maybe the ecm and if where is it located
ANDREWS72400
I have a 90 chevy truck with a built 400 sbc 454 tbi and 350 injectors. i just build it and put it in and to feed the 400 i put a external fuel pressure regulator and a 255lph 100 psi fuel pump. i have it set at about 20 psi and it wont go above that with this fuel pump. with this fuel pump i had to change wiring plug to fuel pump, do you think i may have put wires back wards? the 400 wants more fuel need more pressure.
JDL
  • CERTIFIED EXPERT
  • 16,098 POSTS
I've already told you where the ecm and fuel module should be located, behind the glove box cavity on the passenger side. You need to test the circuits for the fuel module.
RACEFAN966
  • CERTIFIED EXPERT
  • 5,029 POSTS
You are using the throttle body injection correct? The regulator in the throttle body will not let the fuel pressure get higher because it is made to run on 15 psi. If you are trying to maintain the computer then you need to get in touch with Jet Electronics and get the computer redone to accept what you have done. I have done this before for a customer with a 383 stroker and it was a learning curve. The older computers do not like the bigger cams makes them over fuel and then the O2 sensor kicks in and leans it and so forth.
