1997 Chevy S-10 Whistling Noise
ZYANJAY1825
i have a 1997 chevy s10 pickup 4 cyl. just bought it second hand. there was a noise, like a whistling or screaming that we believed to be coming from the fan belt so my friend recommended using "belt dressing". after applying belt dressing the noise got louder so we applied more. soon after the noise went away or so we thought. noise came back but not as loud as before. in fact you can hardly hear anything. it does however present itself loudly when revving the engine. so many opinions on what could still be making that noise, but who to believe. some say bearings need to be replaced, need tension on fan belt, crankshaft, timing belt, the fan itself, replace pulley. please advise on what should be done. thanks!
Jul 3, 2007 at 3:27 PM
DPWD23
  • 136 POSTS
To narrow it down, take the fan off and run for a few minutes (don't forget to put the bolts back in or the pully will come off). If it goes away, your fan clutch is shot. Common problem that causes this noise. If it is still there, get a mechanics scope and listen at each accessory. You should be able to pinpoint where the noise is comming from. Don't forget to wear short sleeves, and be VERY cautious of moving parts when using the scope (of course while it's running).
Jul 10, 2007 at 3:32 PM
Suggested Repair
Remove the fan and briefly run the engine, reinstalling the bolts so the pulley stays on. If the noise stops, the fan clutch is bad and should be replaced. If it remains, use a mechanic's stethoscope at each accessory while the engine is running, staying clear of moving parts, to pinpoint the source.
Conversation Summary
The owner of a 1997 Chevy S-10 4-cylinder reports a whistling or screaming noise first blamed on the fan belt. Belt dressing made it worse, then quieter, but it returns loudly when revving. The expert advises removing the fan and running briefly; if the noise goes away, the fan clutch is bad. If not, listen at each accessory with a mechanic's stethoscope, using caution around moving parts.
