Whenever I unlock my truck with my keyless entry key fob, the parking lights flash, the door unlocks,illuminated SECURITY light flashes normally till door is closed, but engine will not spin when rotating ignition full CW.
I have replaced the Fuse Relay center box under the hood, but still have this problem on occasion.
Is my unlock system failing to disarm the starter kill circuit?
Mr. Goodwrench says if it fails while here in the shop we will analyze it for $90
Mr. Tailgate mechanic says: CHANGE THE IGNITION KEY & CIRCUITRY
Is there any simple solution?
Aug 23, 2010 at 5:17 AM
