Truck wont stay running unless you pump the throttle and keep RPM's up. 60 psi at all times.
Monday, March 31st, 2008 AT 7:01 PM
MASTERTECHTIM
MECHANIC
Is the egr valve stuck open?
SPONSORED LINKS
Monday, March 31st, 2008 AT 7:03 PM
MJG76
MEMBER
Truck starts and runs good for 4 sec then shuts off like out of gas.60 pounds at all times. Dump gas in it will stay runing
Monday, March 31st, 2008 AT 7:37 PM
MASTERTECHTIM
MECHANIC
When it stalls and the key is still on, does the theft light flash?
Monday, March 31st, 2008 AT 7:54 PM
MJG76
MEMBER
No. Ran scanner no codes
Monday, March 31st, 2008 AT 8:02 PM
MASTERTECHTIM
MECHANIC
Does the theft light come on when you turn the key to run? It should come on then go out. Does it? Have you checked fuel injector pulse?
SPONSORED LINKS
Monday, March 31st, 2008 AT 8:08 PM
MJG76
MEMBER
I car play with gas peddle and keep it running
Monday, March 31st, 2008 AT 8:09 PM
MASTERTECHTIM
MECHANIC
Sounds like a stuck open egr valve or a severe vacuum leak. These trucks are notorious for a piece of carbon holding the egr valve open causing this exact symptom.
