Truck stalls while driving
2000 CHEVROLET S-10
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHOPPALA1
My 2000 S10 recently started dying out while I am driving it, but turned over every time that I would try to start it again, the problem kept getting worse until it just wouldnt start unless you let it sit for a few hours even then it wouldnt go more than 100 yards before dying again. I took it to a mechanic and had the fuel filter, fuel pump and battery replaced. It worked fine for about a week and then started up again, doing the exact same thing. I've taken it back to them but they can't figure out what it is. They said it could be a computer chip but they couldnt find anything when they put it on a computer. Please help im running out of options.
Mar 5, 2009 at 10:25 AM
RHALL77
  • CERTIFIED EXPERT
  • 3,361 POSTS
when they hooked up the scan tool do you know if there was any codes. does it stumble when it dies or does it die right away
Mar 5, 2009 at 10:32 AM
SHAWNARENT69
I had this problem got a new fuel pump for $187.00 fixed it
Jan 8, 2020 at 2:14 PM
CAVEMANJB
While driving, the engine just shut off. No sputtering or anything, it just turned off, and the lights and radio and everything stayed on.
The engine will crank, but will not fire up. If I spray starter fluid into the intake it will start for a second and die again.
I have changed the fuel filter and the fuel pump relay. I checked the fuel pump fuse and it's good. The power and ground wires for the fuel pump look good.
Is it time to change the fuel pump?
Jan 8, 2020 at 2:14 PM (Merged)
  • CERTIFIED EXPERT
  • 110,175 POSTS
Before replacing the pump, I recommend checking fuel pump pressure. It sounds like that is the problem, but it is a lot of work and the pump isn't cheap. Make sure to check it first. There could be a problem with the injectors and not the pump. Regardless, you need to first make sure the pump is producing pressure within the manufacturer's specs.
For directions to check fuel pump pressure, go to our homepage under the DIY section. There are directions and there is a video showing how to do it. If you have other questions or need further assistance, let me know.
PEANUTG13
  • 12 POSTS
I was going to work and I was at a stop light. While I was waiting for the light I decided to fix my rear view mirror so I did a quick fix with mounting tape and plugged the electrical part for the map lights and the truck shut off. It didn't start at all and had it towed home. What can it be?
Jan 8, 2020 at 2:15 PM (Merged)
  • CERTIFIED EXPERT
  • 53,872 POSTS
Hey Peanutg13,
It sound like it can be one of two things, either the crankshaft angle sensor has gone out which will make the engine have not spark or injector pulse or the fuel pump has gone out, here are some guides that will help you figure out what is going on.
First,
and then
and
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
and
Please run some tests and get back to us so we can continue helping you.
Best, Ken
PEANUTG13
  • 12 POSTS
I don't have the tools for
Most of that, what u did find out is that a fuse of crankshaft was broken so I replaced it but it still didn't start. I would think it would be an electrical problem seeing as when I plugged in the rear view mirror lighting the truck shut off, also I noticed that after the truck shut off I unplugged the rear view mirror and when I plug it in it's on and won't go off even when I turn of dome lights and close the door
  • CERTIFIED EXPERT
  • 53,872 POSTS
Hey PEANUTG13,
Yes this does sounds like a BCM problem that will need to be replaced or the wiring damage found and repaired. Here is the wiring diagram for the BCM so you can starting looking around. It does look like there is a heated mirror relay that is tied into the engine ignition fuse. Try removing the relay to see if that helps.
Best, Ken
PEANUTG13
  • 12 POSTS
I found out that it was the "ecm b" fuse. So I replaced and it and it started right up but as soon as I accelerated, the fuse blew. So I asssume there is a short somewhere. I put a higher amp fuse to move it back into a parking. Do u think it will run with that higher amp fuse or should I just look for the short?
ROGER6632
  • 19 POSTS
used it the other day,ran good,tried it today,it started but rocked and jumped went like that for a minut
tried to start again,just kept cranking,didn,t even try to start.had this problem before,the plug in for the fuel
pump burnt,only one pin,the one that makes it pump,so i pulled the wire off and hooked it in the front
worked good like that for 7 months untill today.i unpluged that one pin,pushed it back on and it ran for like
10 seconds,sounded good,unplug it again and ran for 10 secounds again.i pored alittle gas in the motor
it started up ran a few secounds,would you say it,s most likely the fuel pump??????
fuel pump was 2 years old.thanks
  • CERTIFIED EXPERT
Try running it direct from the battery and start it and see what happens
  • CERTIFIED EXPERT
  • 53,872 POSTS
Hey, PEANUTG13
Good find on the fuse, I would look for a short. Start the truck up and let it idle. Then start moving the wiring harness around it see if the truck stalls, this will give you an idea where the short is.
Best, Ken
  • CERTIFIED EXPERT
See if it stays running if so check the fuel pump relay
ROGER6632
  • 19 POSTS
.when I turn key on I can hear
the pump run,and like I said
it would run for a few secouns
and die,I don,t have a fuel
pump tester,but I did push the
pin in on the fuel line plenty
of pressure
  • CERTIFIED EXPERT
Depressing the schrader valve don't mean nothing we need to know if the fuel pressure is within the specs-This is where we should start the diagnosis-The pressure should be 60-66psi
AMPROFFITT
Engine Mechanical problem
2000 Chevy S-10 4 cyl Two Wheel Drive Automatic
I have a 2000 Chevy s-10 2.2l non flex fuel automatic trans. It starts and runs for approximatley a second then dies. It is not losing spark. I replaced the fuel pump less than a year ago, and have jumped across the fuel relay to keep the pump running. if i spray fuel into the intake as it starts it will start and continue to run until i stop spraying fuel. if i dont spray fuel into the intake, it will start, and then die almost immediately. please help.
  • CERTIFIED EXPERT
Check the fuel pressure to rule out the fuel filter and fuel pump if okay test the fuel pump and oil pressure sending unit
ROGER6632
  • 19 POSTS
ok,pressure was 40 lbs,i put a new pump in and it will start
and run for like 5 seconds and then run rough for a couple seconds.
i have no clue whats going on.fuel filter was changed a year ago
INTERNETMECHANIC
  • CERTIFIED EXPERT
  • 700 POSTS
Do you think the security system is causing a problem? Passlock is an injector disable, may start then die. When the vehicle dies, if the security lite is on, leave the key on, the lite may go off in about ten minutes. Turn the key off for 5 seconds. Do the sequence twice more, about thirty minutes. That is a relearn procedure, maybe it will start, then.
BURNS.316
My truck would not start with low fuel in the tank. I never had a problem if I kept more than 5 gallons in the tank, then I let it get low once and couldn't get the engine started. I put gas in the air intake and ended up damaging the line. I replaced the air line and resonator that were damaged. I then replaced the plugs and fuel filter, because I thought that the fuel filter was dirty (I think it was 100,000 miles old) and the plugs were about 40K old. After replacing the filter the truck started right up and I have had no starting problems (although there is 1/2 tank of gas). I drove home from the garage and the truck seemed fine. However, now when I am driving the engine will often hesitate and stall. If I rev the engine in neutral it seems normal. When this started it would stall if I went to accellerate at high speed (60+ MPH) now it will hesitate at lower speeds and stall what seems randomly. Occasionaly when the truck stalls I can not get it to start without pulling over and putting it in park, removing key and then cranking. I thought maybe the gas has gone bad and put 5 gallons of premium in with the 5 gallons that were in the tank(I usually run 87 octane as recommened), now it still hesitates and may stall but it is much harder to actually get the truck to stall.
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
When it stalls, you need to test for fuel presssure and spark.It sounds like it may be a weak fuel pump or one that is going out, but you need to verify this with a pressure test using a gauge
BURNS.316
I filled the other half of the tank with premium, so there are now 3 gallons of new premium for every gallon of suspicious gas that was in the tank. The one trip home I made the truck did not hesitate or stall, even with agressive acceleration. Does this mean I had bad gas, or will filling the tank help an ailing fuel pump? I have an appointment on Tuesday to use the garage again and will check the pressure in the fuel rail, but if I don't have any problems between now and then does that mean bad gas or should I still worry about the fuel pump going out?
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
Normally more fuel in the tank wont help a bad pump. A pressure test will help rule it out.Have you troed a product in the fuel tank to remove moisture?
BETH HUSTON
What is the name/names of the sensors that could be part of this problem?
BURNS.316
I put some heet in there last tank of gas. I have another bottle left if I should use that. Today I drove for an extended trip with no stalling, but there was a little hesitation. I also ran diagnostics from the computer and it came back with two error codes:
P0171 = Fuel system for bank one too lean.
P0133 = Response time for oxygen sensor 1 in bank 1 too slow during testing.
So I picked up a new oxygen sensor and plan to install it on tuesday. Could that have been causing the problem as described?
BETH HUSTON
If I let the truck sit for a few minutes then I restart it & take off again. But not for very long. That I should put that in there as well. Thank you
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
Its posible, but check for vacuum leaks first.Low fuel pressure can cause a lean code as well
CJ MEDEVAC
  • CERTIFIED EXPERT
  • 11,004 POSTS
Up at the top of this page, beside "SEARCH" is a heading "REPAIR GUIDES", If you scroll thru it there are many articles "how tos/ diagnosing issues/ etc
Under "ENGINE" I picked this one up for you. Link below.
https://www.2carpros.com/articles/engine-stalls
If you kinda need guidance on things discussed in there, many are shown in that same repair guides section (such as the crank sensor, and more)
Return here with good news!
or
Need further help or more questions
If I am unable to assist further, others here very often jump in and help, or I will find someone who can for you!
The Medic
JWSTEE
My chevy S10 quite while driving.
Checked fuses, filter, fuel pump is not turning on.
put new fuel pump on about 10,000 miles ago.
no problems since replacement until now.
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
[quote:7db9ff8f77="jwstee"]Electrical problem
2000 Chevy S-10 4 cyl Two Wheel Drive Manual 119000 miles
no problems since replacement until now.[/quote:7db9ff8f77]
check the fuel module fuel pump
also check the connector at the module very common (wiring side)
ROGER1966
  • 5 POSTS
2000 s10 2.2 flex fuel engine. Truck will just die going down road. But will start right back up.
  • CERTIFIED EXPERT
Start by checking and monitoring the fuel pressure to rule out a failing fuel pump-check fuel filter
ROGER1966
  • 5 POSTS
filter is just been changed. Pump is new.
  • CERTIFIED EXPERT
If it starts right back up with no problem. I suggest again you check the fuel pressure with a gauge even though its a new pump-
