2000 Chevy S-10 Oxygen Sensor bad?
BUSHPILOTCHUCK
  • 2000 CHEVROLET S-10
  • 4 CYL
  • 50,000 MILES
My Chevrolet S10 is burning more fuel now. My OBDII scanner gives the following readings for the oxygen sensors:
O2 B1 S1 shows fluctuations from.1 to.7mv
O2 B1 S2 shows a constant.7mv
This is in Closed Loop after warm up.
The O2 and CAT monitors show that they have not completed their monitoring.
I appreciate your help.
Friday, October 31st, 2008 AT 1:40 PM
MERLIN2021
  • 17,250 POSTS
Your 02 readings look OK, check/clean the MAF, it controls injector pulse width.
Friday, October 31st, 2008 AT 6:54 PM
BUSHPILOTCHUCK
No MAF on this vehicle. Checked the MAP sensor and it seems to react slowly. Thinking it might be contaminated. Can it be cleaned?
Tuesday, November 4th, 2008 AT 11:00 AM
MERLIN2021
  • 17,250 POSTS
Ok here's the sensor range charts, you need to check them starting with the 02.
ARTICLE BEGINNING INTRODUCTION Sensor operating range information can help determine if a sensor is out of calibration. An out-of- calibration sensor may not set a trouble code, but it will cause driveability problems. DFT (1), ECT (2) & IAT (3) SENSOR RESISTANCE (EXCEPT TRACKER)
NOTE: Unless stated otherwise in test procedure, perform all voltage tests with a Digital Volt-Ohmmeter (DVOM) with a minimum 10-megohm input impedance. Temperature - °F ( °C) (4) Ohms 212 (100) 177 194 (90) 241 176 (80) 332 158 (70) 467 140 (60) 667 122 (50) 973 113 (45) 1188 104 (40) 1459 95 (35) 1802 86 (30) 2238 77 (25) 2796 68 (20) 3520 59 (15) 4450 50 (10) 5670 41 (5) 7280 32 (0) 9420 23 (-5) 12,300 14 (-10) 16,180 5 (-15) 21,450 -4 (-20) 28,680 -22 (-30) 52,700 -40 (-40) 100,700 (1) Diesel Fuel Temperature (DFT) sensor. (2) Engine Coolant Temperature (ECT) sensor. (3) Intake Air Temperature (IAT) sensor. (4) Measure resistance across sensor terminals. Page 1 of 3 SENSOR RANGE CHARTS -2000 Chevrolet S10 Pickup
MAP SENSOR VOLTAGE OXYGEN SENSOR VOLTAGE THROTTLE POSITION SENSOR VOLTAGE
Throttle Position (1) Volts At Idle 1.0-1.5 Wide Open Throttle 4.0-4.9 (1) Measured at sensor, or as seen on scan tool. Ensure sensor output changes instantly when intake manifold vacuum is applied and released. Condition (1) Volts Lean.1 Rich.9 (1) Measure voltage between oxygen sensor ground and signal terminals at PCM/VCM. Throttle Position (1) Volts At Idle 0.6 Wide Open Throttle Greater Than 4.0 (1) Measured at sensor, or as seen on scan tool.
Thursday, November 6th, 2008 AT 1:26 PM
