2000 Chevy S-10 AXle rebuild Seals and crush sleeve
110,000 MILES • 4 CYL • 2WD • MANUAL
DEONCOLLINS69
I have my rear axle ready for reassembly. I had a leaking pinion seal and decided to replace it. I went to remove the flange with a four jaw puller and it would not move. The puller was wedged so I tapped it with a brass hammer and I knocked the pinion loose and assume I knocked the depth out of spec. I am re-using all of the hard parts and have them all laid out ready o reinstall with new seals and a new crush sleeve. I'm assuming I need to reset the depth and reset the rear end for assembly. I have the dial gauge and a set thickness gauges also. Since I am reusing the old bearings and shims what do I need to reset and what to adjust. I've tore down and fixed everything else on a car but this is my first rear end build. Thanks in advance.
Oct 1, 2009 at 5:33 AM
HMAC300
  • 48,601 POSTS
you are not changing the gear so you DO NOT need to reset the depth. Re-assemble everything BUT ONLY PUT ABOUT 5 inch pounds of preload on the pinion bearings. Anything more than that and you will burn them up. Be very careful as you are using a new crush sleeve and it can go to tight with everything. There is no need to change the shim pack in anyway.
Oct 2, 2009 at 11:50 AM
