1999 Chevy S-10 Parts location
1999 CHEVROLET S-10
IRICK55
Electrical problem
1999 Chevy S-10 4 cyl Two Wheel Drive 87000 miles
I purchased a new Electronics flasher for my PU I have MS very difficult to gtet under the dash. Haven't been able to locate the flaser to replace it. Can you give me the location were it should be.
Thank You
Jun 4, 2010 at 12:34 AM
INTERNETMECHANIC
  • 700 POSTS
My info says the turn flasher is under the dash, passenger side. I haven't found a picture of location. I guess your talking about the turn signal flasher?
Jun 4, 2010 at 1:56 AM
PAPAROACH
turn signal flasher is located behind glove box. Push/pull spring that keeps door from opening all the way and you will see flasher to the right. Usually has a tie wrap around it.
Jun 14, 2010 at 4:49 AM
