First check your fuel pressure, is it too high? If so it will cause too much fuel to come out.
Also your injectors could be leaking or hanging open. You sure the ones you had in the garage were the proper pound injectors for your vehicle, if your putting in injectors that put out 1 more pound of fuel that could cause quite the drain.
SPONSORED LINKS
Sunday, December 28th, 2008 AT 6:16 PM
