1998 Chevy S-10 MAF?
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
MKELLEHER712
I own a 1998 Chevy S-10 V6 4.3L. I just recently did a tune up on my truck and ever since the tune up the engine will shake when I tap on the gas. If i floor it the engine will not shake. My check engine light was on and when I did the test it said MAF Sensor and Miss fire. I changed out the MAF correctly but the engine still shakes. What could it be? And what should be my next move?
Oct 30, 2009 at 8:23 AM
  • 110,248 POSTS
Did the shaking just start since the tune up? Did you properly gap the spark plugs? Are you sure that the ignition wires are on in the correct order? Have you checked to make sure none of the wires are arcing causing a miss?
Nov 12, 2009 at 2:35 AM
