1998 Chevy S-10 IAC? MAF? TPS?
1998 CHEVROLET S-10
131,000 MILES • 4 CYL • 2WD • MANUAL
DAYTONANITE
Hello. I just purchased a 1998 S-10 with a 2.2L, manual trans. Cold starts are fine and it runs good till I shut it off. Upon warm starts, more often than not, it will crank as if it is not getting fuel. If I mash the gas petal to the floor, it will start, puff some black smoke, and idle rough for a few seconds, then it is good to go.
To me, it almost seems like the IAC motor is sticking, but then I feel as if it could be the MAF sensor. If you have any ideas, I would appreciate the feedback. Thank you.
Apr 23, 2009 at 2:30 AM
BUDDYCRAIGG
  • 2,262 POSTS
Sounds like a leaking fuel injector, and the engine is flooded.
Apr 23, 2009 at 2:40 AM
DAYTONANITE
[quote:6c457d5e0f="buddycraigg"]Sounds like a leaking fuel injector, and the engine is flooded.[/quote:6c457d5e0f]
That's what I thought at first, but while it acted up, before starting, I checked the fuel rail and there was pressure there. If it was a leaking injector, there would not be pressure in the fuel rail before turning the ignition on.
Apr 23, 2009 at 4:49 AM
BUDDYCRAIGG
  • 2,262 POSTS
depends on how bad the leak is. you would have to let it sit with a pressure gauge on it to get an accurate idea.
You have too many things suggesting it's flooded.
Mashing the pedal down to the floor is how you clear a flooded fuel injected car.
You get a puff of black smoke.
and the stumbling idle until the extra fuel is cleared.
That's all I can suggest you test at this point. is to see if the presser bleeds down. presser testers are only about 35 bucks.
Apr 23, 2009 at 5:48 AM
