1998 Chevy S-10 evap
204,245 MILES • 6 CYL • 2WD • AUTOMATIC
VTX1300
truck runs good when first started up let run 20 minutes and drive. when i come to a stop it will run rough and back fire through te intake go dead will not restart until it cools down, ten it will run good till it warms up again.
Mar 14, 2010 at 12:03 AM
HMAC300
  • 48,601 POSTS
get it scanned, alot of auto parts stores do this. it could be the crank sensor because it heats up and quits. You would need to check the ohms. tere could be other things as well, but it' better to have a pro check it due to him havig access to stuff that you or an atuo parts store wouldn't have...
Mar 15, 2010 at 5:15 AM
