Computer problem
1998 Chevy S-10 4 cyl Two Wheel Drive Manual
my truck wont start. The check engine light is on and when I put a obd2 on it it says no codes and wont start
Tuesday, January 13th, 2009 AT 6:18 PM
DE772601
MEMBER
Hello first check to see if you are getting spark and fuel and if so then you may have a pcm problem, but first check those two parts first. See if this will lead you in the right direction.
SPONSORED LINKS
Tuesday, January 13th, 2009 AT 7:35 PM
RYANPRINE
MEMBER
I am geting spark and fuel. The injecters are not going on and I replaced them and also the pcm
Tuesday, January 13th, 2009 AT 7:52 PM
DE772601
MEMBER
Check also to see if you have a body control module that may be causing the truck not to start its located in the middle the the truck on the floor by the gas pedel should be 3 big plugs that are plugrd into it. Hope this will help.
Tuesday, January 13th, 2009 AT 9:40 PM
RYANPRINE
MEMBER
Wut does the body control do
Tuesday, January 13th, 2009 AT 9:45 PM
DE772601
MEMBER
Thats tied in with the pcm which will control the conponets inside the truck. Which may not be sending a siginal to the pcm.
