Our 97 S10 Blazer is leaking oil from the oil line than runs from the filter adapter on the engine to the remote filter located in the front of the car below the radiator. I have a new line and have the old line loose, but am having difficulty removing the line due to obstructions like the motor mounts, etc. Not much room! Is it possible to remove the line without unbolting the motor mount? If so, what is the trick? If not, what is the process to unbolt the engine from the motor mount?
Thanks!
Thanks!
Jan 10, 2008 at 4:10 AM
