1997 Chevy S-10 gear oil, differentials
TWD22285
  • 1997 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 83,000 MILES
I found where the fill port is, to put in the gear oil for my differentials. However I can not find the drain for it. Also what weight gear oil oil is recommended.
Tuesday, January 27th, 2009 AT 4:14 PM
RHALL77
  • 3,361 POSTS
Check your owners manual it shoud have the weight for you. The drain is at the bottom of the diff towards the drivers side I think on the front diff. The rear you have to pull the cover off and drain it that way
Tuesday, January 27th, 2009 AT 4:18 PM
Related General Content
