1997 Chevy S-10 Check light on
JOYCE L. OVERSTREET
  • 1997 CHEVROLET S-10
  • 6 CYL
  • 118,000 MILES
Been having problems with my truck wanting to stall almost when I am sitting at a light or something and it just does not really want to go. I have had it put on the machine 2 times and it says my truck is running lean but can't seem to find out why it is doing this. It is like it is losing power and then speeds back up. Goes up and down like this when I am sitting still. When this is happening the gas gauge moves up and then when it speeds back up the gas gauge goes back down.
Saturday, December 27th, 2008 AT 8:19 AM
BMRFIXIT
  • 19,053 POSTS
Need more info and detail from you
what I got is that u have a check engine light with lean codes
if u can get me the code s # will help
most common with lean mixture code is vacuum leaks
check intake gasket
also remove and check clean EGR valve (checking for carbon build up )
also check MAF sensor as it will give you a lean codes too
good luck
Saturday, December 27th, 2008 AT 8:41 AM
JOYCE L. OVERSTREET
Thanks! You are great, I will get this checked today!
Saturday, December 27th, 2008 AT 8:48 AM
