1996 Chevy S-10 engine quits
HAMMER6315
  • 1996 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 160,000 MILES
While driving down the freeway the engine 'bucked' and then quitwhile cruising at ~60mph. After sitting for a few minutes it started and I drove toward home. It did the same thing twice more brfore I could get it home. Clogged fuel filter? Bad fuel pump? I have put the last 25k miles on it.
Monday, March 1st, 2010 AT 12:51 PM
RICKYMEARS
  • 5 POSTS
Is your fuel pump cutting out?
I am having a similar problem w/ a '96 Isuzu Hombre. My truck will run but then quits. The relays in the glove box are getting overheating and failing is my guess but I don't know the underlying cause. I have replaced my fuel pump and those relays. When ever it dies on me and I attempt to start it right after wards I can't hear the fuel pump cycle. Is your problem like mine? What have you done?
Thanks.
Tuesday, April 13th, 2010 AT 3:51 PM
