When you get emission tests it is best to change the oil and filter before you go so you get the fuel out of the oil. Fuel will build up in the oil and affect your tests. Then drive the vehicle at least 15 miles on the exspressway if possible. Then go get it tested. This usually takes care of things. If you live on a gravel road and it doesn't matter if it's only a block, your air filter should be changed once a year. If you haven't changed it in a while then it's good to change it.
Thursday, October 28th, 2010 AT 6:49 PM
