1996 Chevy S-10
BRUCELEX
  • 1996 CHEVROLET S-10
  • 4 CYL
  • 101,000 MILES
Put a new starter on, but cant start from key you can cross out the starter and will start whhat else can I do, what esle can I check
Tuesday, August 19th, 2008 AT 10:24 AM
ROB2008
  • 258 POSTS
Did it use to start form the key before you put the started in?If so look at the wiring. If not . It may be the ignition switch.
Tuesday, August 19th, 2008 AT 11:01 AM
BRUCELEX
When we put the new starter in it work for a day then quit
Tuesday, August 19th, 2008 AT 3:23 PM
