Saturday, August 7th, 2010 AT 6:40 PM
Hello, my 1995 chevorlet s10 blazer "chokes" itself at 2300-2500 rpms and will kill itself. When it dies, it will crank over, but wont start without starting fluid. I have replaced the fuel pump, filter, and both relays. Scaned the computer (obd2) and it wont throw any codes. The heated o2 bank 1 sensor 1 was faulty, is it was replaced as well. All sensors test fine. (Tps, map, ect.) I have fuel pressure all the way up to the fuel rail. I dont know where else to start. The spark is fine as well. I had a cold air intake on it as well, but replaced the air box and no luck. Any advice? It would be greatly appreciated.
