1995 Chevy S-10 brakes lock up at low speeds
1995 CHEVROLET S-10
241,970 MILES • 4 CYL • 2WD • MANUAL
SLICX
  • 9 POSTS
i just had the battery replaced and my breaks lock up at parkinglot speeds. i dont know if i have abs or not. i have tried looking for the abs relay but was unable to locate it. i dont know which wheels are locking up but i belive the primary breaking problem is in the rear set.
Nov 11, 2009 at 8:56 AM
  • 110,244 POSTS
Have you checked to see if there is a wheel cylender leaking or axle seal? If everything is dry, does the problem go away after driving? Also, can you describe what is happening?
Nov 11, 2009 at 11:35 PM
