1995 Chevy S-10 6 cyl Two Wheel Drive Automatic 213 K miles
I have a 1995 chevy s-10 v-6 TBI. The truck runs great if the temp. Stays below 210 deg. Something happens at 210 deg. The truck acks like its going to run out of gas, backfires through the carb, the exhaust, stalls out. If your sitting in a fast food drive thru the temp. Goes up to 210 plus, and sometimes stalls out. But as soon as you start to move the temp. Comes down. I have replaced fuel pump, fuel filter, radiator, clutch fan, air filter, temp. Sensor, o2 sensor, cat converter, plugs, plug wires, cap & rotor.
Still the same, Like I said you can beat the crud out of this truck below 210 and it runs great, but 210 or above you really got to feather the gas to get the truck to move untill temp. Drops. I also checked for codes, the was none. Anybody have the same problem or know how to fix it? Thanks
P.S. I'm thinking of changing the fuel reg. With injectors, What else is left?
SPONSORED LINKS
Monday, June 23rd, 2008 AT 12:16 PM
