HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
S-10
Engine
Symptoms
Idle High
1994 Chevy S-10 high idle
RAYMOND SYMONS
MEMBER
1994 CHEVROLET S-10
6 CYL
2WD
AUTOMATIC
91,000 MILES
No vacum leaks but the idle stays high I have knocked out the plug and tryed to lower set screw for idle but stills idle high
Monday, February 4th, 2008 AT 8:58 PM
MECHANIC
Could be a sticking throttle plate or the throttle position sensor out of range and idle air control valve
Tuesday, February 5th, 2008 AT 2:21 AM
Please
login
or
register
to post a reply.
Related Engine Idle High Content
1986 Chevy S-10 No Temp. And High Idle
I Have Two Problems. The First Is The Temp Gauge Always Reads At The Lowest, Heater And Defroster Both Put Out Heat, Both Lower And Upper...
Asked by
larry12b
1986
CHEVROLET S-10
1991 Chevy S-10 Will Idle Forever But Wont Pull...
Sounds Like The Engine Bogs Down And Then Dies. Was Able Drive About 3 Blocks And Then Bogged Down And Died. Would Not Restart Right Away...
Asked by
philipb645
1991
CHEVROLET S-10
1986 Chevrolet S-10 S10
S10 Idles High An Low An I Can Rev It Up. But When I Put It In Gear An Give It Gas It Backfires Thru The Intake An Cuts Off An It Will Crank...
Asked by
robwilli2012
1986
CHEVROLET S-10
Engine Losing Power?
My S10 Cranks And Idles Fine. However, Once It Warms Up, It Loses Power On The Slightest Incline. This Has Been Getting Progressively...
Asked by
Brad04
1994
CHEVROLET S-10
1994 Chevy S-10 1994 S-10 Fails To Start After...
Electrical Problem 1994 Chevy S-10 6 Cyl Four Wheel Drive Automatic When Attempting To Restart My S-10 Blazer After It Has Been...
Asked by
lostinacar
1994
CHEVROLET S-10
VIEW MORE
Vacuum Leak
Vacuum Leak Symptoms
Vacuum Leak Test and Repair
