1994 Chevy S-10 fuel pump
DRYERT
  • 1994 CHEVROLET S-10
  • 4 CYL
  • 180,000 MILES
How do you take the fuel pump off the gass tank after the gas tank is all ready off
Thursday, January 17th, 2008 AT 3:01 PM
PEAR69
  • 1,482 POSTS
VERY VERY carefully. There is either a large c-clip or a locking cam. The c-clip just needs to be pryed out like any other c-clip. The locking cam turns like a large nut. There are tabs on the cam that you turn--taping them with a block of wood is the best way to turn these cams. Wood will not make any sparks. Do not tap these cams with anything metal. Spraying some wd-40 on these cams helps.
Thursday, January 17th, 2008 AT 11:07 PM
