1993 Chevy S-10 Engine stops for an hour or two
MORTAS
  • 1993 CHEVROLET S-10
  • 6 CYL
  • MANUAL
  • 203,000 MILES
Engine stops after driving a few miles and will not start sometimes up to two hours. Replaced the egr valve. What is next?
Wednesday, December 10th, 2008 AT 9:53 PM
Engine stops after driving a few miles and will not start sometimes up to two hours. Next time it happens do below immediately to determine if its fuel or spark issue
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Thursday, December 11th, 2008 AT 7:29 AM
