1992 Chevy S-10 gear pop
125,000 MILES • 6 CYL • 2WD • MANUAL
MENACEINDUSTRIES
On my Chevy S-10, I have recently replaced the clutch and now I am having the issue with first and second gear popping out when I go to take off. Is it because of a damaged gear or something that might be simpler than that?
Dec 21, 2007 at 7:34 PM
  • 31,937 POSTS
Hi there,
If this was not a problem before the clutch was replaced. Check that the gear box is tight on the engine, the rear gearbox mount is aligned as it was before, (you should be able to see where it was siting) this sounds like a miss alignment problem.
Mark (mhpautos)
Dec 21, 2007 at 7:41 PM
