First find the dipstick, it should be on the passengers side, by the firewall. Look down the side of the engine by the bell housing. It could be covered by a heater hose making it hard to see. See if the dipstick is in place and check to see if it was partially out to cause fluid to leak in the duct. Also check the transmission line coming from the transmission cooler to see if there is a leak.
SPONSORED LINKS
Monday, December 9th, 2019 AT 9:49 AM
