1988 Chevy S-10 S10 computer problems?
PITBULLKEN
Computer problem
1988 Chevy S-10 6 cyl Two Wheel Drive Automatic
I have a 1988 S10 pickup with a 2.8 v6. It will run for about 20 to 30 minutes until it gets good and warm then it will blow a fuse and quit running. after replacing blown fuses and cooling down it will run again for 20 to 30 minutes. Any advice would be appreciated.
May 4, 2008 at 12:21 AM
BMRFIXIT
  • 19,053 POSTS
You need to check the circuit that is
controlled by that fuse
check it for short to ground
also check for over drawn on that circuit
check if you have any wires touching the exhaust system
May 4, 2008 at 12:41 AM
