got a 1986 s-10 2.8 throttle body idles high and runs lean. if you drive it like an old man runs like crap but if you drive it like a race car and keep the rpms up it dont seam to bad 1st and 2nd gear runs rough 3rd and 4th run smooth checkd codes found only one something to do with speed sensor malfunction ive replaced idle air contoll valve and fuel filter and o2 sensor and injectors why dose it fall on it face if you try to drive it like a old man would
Oct 21, 2010 at 4:54 AM
