2002 Chevy Prizm
VINCIA1
  • 2002 CHEVROLET PRIZM
  • 4 CYL
  • FWD
  • 106,000 MILES
Greetings. My vehicle's registration was up for renewal and besides paying the annual fee, this year required a smog check (I am a CA resident). The vehicle did not pass the smog check, and further is classified as a "gross polluter." The vehicle has not had a muffler replacement, but I always have the required preventive maintenance done when the time comes.
One important question I have is that it was not necessary to drive the car for seven months; I only started the engine (usually once a month), but the car leave the parking structure from August until the smog check. Could driving the vehicle regularly affected the outcome of the smog check and its current status as a gross polluter?
Thanks!
-Vince
Saturday, April 18th, 2009 AT 7:38 PM
MMPRINCE4000
  • 8,548 POSTS
Yes it will.
When storing a car for any length of time (30 days or more), you should pour a fuel stabilizer in the tank. Gasoline wll start to detereoriate in about a month.
It will cause varnish build up in the fuel system including injectors.
I would siphon all the gas I could out of the car and use an additive like "SeaFoam" in the tank and then fill with fresh gasoline.
Drive everyday for a couple of weeks, the refill tank and add another can of SeaFoam.
This should clean up the fuel system.
Always buy gasoline from a station that pumps a lot of gas, so they refill their tanks at least once a week.
When storing again, use a fuel stabilizer like "Stabil" in the tank to kep the gas fresh for 12 months.
Sunday, April 19th, 2009 AT 7:18 AM
