1970 Chevrolet El Camino Stuck Bendix
CHEVROLET
JOEWR
I have a 70 El Camnio and I reublit a 77 305 out of a Monte Carlo for it. I built it from scratch, but i know my block and flexplate are correct. However, the starter i installed makes a whirring noise when cranking (truck wont start, seems to be slow cranking) and when i go underneith to check, the bendix is ALWAYS stcuk in the flexplate. When I loosen the starter the bendix snaps back. I have shimmed this every way you could imagne and i still get noise and stuck bendix. My flexplate, battery, cables are all good. Any advice? Thanks, Joe
Aug 22, 2007 at 3:43 AM
  • 75,988 POSTS
[quote:a88d758038="JoeWR"]Hello,
I have a 70 El Camnio and I reublit a 77 305 out of a Monte Carlo for it. I built it from scratch, but i know my block and flexplate are correct. However, the starter i installed makes a whirring noise when cranking (truck wont start, seems to be slow cranking) and when i go underneith to check, the bendix is ALWAYS stcuk in the flexplate. When I loosen the starter the bendix snaps back. I have shimmed this every way you could imagne and i still get noise and stuck bendix. My flexplate, battery, cables are all good. Any advice? Thanks, Joe[/quote:a88d758038]
You have a problem with hold/pull winding on the solenoid or the shift lever return spring or an overrunning clutch problem-bottm line new starter.
You sure you got the correct starter? Noise before engine starts your too far from the flexplate-noise after starts-too! close. Engage the pinion to the flexplate manually there's a hole on the starter to do that. and check your .020 clearance between 2 teeth on flexplate and pinion-then go from there shimming it.
When you engage the starter is it growling/moaning after a start or whatever.
Aug 25, 2007 at 12:53 PM
Suggested Repair
Replace the starter if the solenoid hold or pull windings, shift-lever return spring, or overrunning clutch is faulty. Confirm it is the correct starter, manually engage the pinion, set about 0.020 inch clearance to the flexplate teeth, then shim as needed. Noise before the engine starts indicates the starter is too far from the flexplate; noise after starting indicates it is too close.
Conversation Summary
The owner of a 1970 Chevrolet El Camino with a rebuilt 1977 305 reports whirring and slow cranking, and the starter Bendix remains stuck in the flexplate until the starter is loosened. Shimming and known-good flexplate, battery, and cables did not help. The expert attributes the problem to the solenoid windings, shift-lever return spring, or overrunning clutch and recommends confirming the correct starter, checking about 0.020 inch pinion clearance, and installing a new starter.
