Yesterday morning was a bit chilly maybe 29 degrees. I went out to go start the car to warm it up. Once I started it. It made a really high pitched almost whinning noise. Consistently. I then shut the car off. Took the keys out. The noise was still going.I opened the hood. The fans were still running. Once the car warms up. The noise tends to go away. But after I shut it off. The fans still run. For a while afterwards. So by the fans running all the time. No matter if I drive for a long period of time. My tem gage doesnt move at all. It stays as it was when I first start it up.
After a day the check engine light came on.I got the code read and it's P0128 coolant temp. Where is this sensor located and how do I replace it
SPONSORED LINKS
Monday, December 11th, 2006 AT 10:05 AM
