Ok, here's a few other things to look into. Injectors, ignition moduel, or even the catalityic convertor, (if cat, the engine will bog down). Also make sure the air box, (where the air filter is located) is no blocked up. I had a problem on a customers vehicle once, where a squirrel built a nest inside the air duct on the car. (Not likely but doen't hurt to check). Good luck :)
SPONSORED LINKS
Wednesday, December 13th, 2006 AT 6:16 PM
