2006 Chevy Trailblazer No Door Power
CHEVROLET
MARCIETM
2006 Chevy Trailblazer Exteneded. First of all, it was raining very hard. Yesterday I came out to the car to find my driver window 3/4 of the way down. It was closed when I went into the store. Now, the whole driver door module has no power to it.....unable to adjust mirror, no power lock in the door, no power windows, no seat warmer. The rest are fine. I did change out the Driver Door Module fuse but it still is not working. Any suggestions?
Feb 25, 2007 at 9:23 AM
CHEVY22
  • 1,375 POSTS
pull the switch out of the door and check for power while bumping switches , you may have burned out the master window /lock switch
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge
Feb 25, 2007 at 9:57 AM
MARCIETM
What switch should be pulled out of the door and exacty where can I find it? Also, what do you mean by "bumping switches"?
Thanks so much! :)
Feb 25, 2007 at 11:15 PM
CHEVY22
  • 1,375 POSTS
the door lock/windowswitch and ny rocking i mean from on to off a few times to check power , on both sides
Feb 26, 2007 at 12:58 AM
MARCIETM
Thank you for trying to assist me. It seems, though, after taking it to the dealership, that the driver door module burned out inside. They aren't sure what caused it yet, but certainly nothing I can fix on my own. Thanks again.
Feb 26, 2007 at 11:58 AM
Suggested Repair
Remove the master door lock and window switch and check for power while cycling the switches on and off. If power is absent, the driver door module may have failed internally and needs replacement rather than a DIY switch repair.
Conversation Summary
On a 2006 Chevrolet Trailblazer Extended, the driver window was found partly down after heavy rain, and the driver door then had no power for the window, locks, mirror, or seat warmer. Other doors still worked, and replacing the driver door module fuse did not help. An expert suggested removing the master lock and window switch and checking for power while cycling it. The owner later reported that the dealership found the driver door module burned out internally and that it was not a DIY repair.
