1997 Other Chevrolet Models Water temp gauge
1997 CHEVROLET
107 MILES • 6 CYL • 2WD • AUTOMATIC
BIKETUNE
The temp gauge in my 1997 Chevy P30 Step van was not working, after tracing the wires that go to the temp sender on the left side of the engine, I noticed that one wire was broken coming out of the connector. I just spliced the wires together. The gauge now works, but the temp gauge goes to full hot with the key off, is that normal?
Feb 19, 2009 at 11:31 PM
BLUELIGHTNIN6
  • CERTIFIED EXPERT
  • 16,542 POSTS
Should go to C (Cold) with key out. Might want to inspect other wires as well. Sounds like a wire is hooked up wronged on sender.
Thanks for using 2CarPros.com!
Feb 20, 2009 at 2:00 AM
