1996 Other Chevrolet Models Spits back through injector body
1996 CHEVROLET
46,000 MILES • V8 • 2WD • AUTOMATIC
SCHUELKE
I have a 96 Motorhome with a chev 454 , fuel injection. It spits back through the injector body when I step on the gas hard. rough idle and high speed miss. I have replaced the rotor,cap, wires, and plugs. checked for vacum leaks and found none. cleaned the air filter,it has a washable element. I checked for codes and there are none. I did just fill up the gas tank, could it be bad gas or dirt in the system?
May 9, 2010 at 4:18 PM
DOCFIXIT
  • 18,828 POSTS
Have you checked engine compression?
May 10, 2010 at 1:57 PM
SCHUELKE
I did not because it was running fine the day before. I filled the gas tank on my way home and the next day when I went move it is when it started to act up. That is why I thought it might have been the fuel.
May 10, 2010 at 6:06 PM
DOCFIXIT
  • 18,828 POSTS
Was it contaminated fuel?
May 18, 2010 at 1:15 PM
