1995 Other Chevrolet Models tack drops wont shift out of sec
APPLIANCEXCHANGE
MEMBER
1995 CHEVROLET
Electrical problem
1995 Other Chevrolet Models Two Wheel Drive Automatic 200000 miles
tack drops wont shift out of second only acts up once in a while no one can find problem here in SC29461
Saturday, April 3rd, 2010 AT 6:27 AM
HMAC300
MECHANIC
If the tach drops then i'd think maybe a ground is bad. As far as not shifting out of 2nd that usually is an indication that the trans is failing. But this could be a ground as well if it happens at the same time. You should have a eninge to battery ground, body to battery, etc. Those may be the difference.
