1990 Other Chevrolet Models
1990 CHEVROLET
SRRJ
1990 Other Chevrolet Models V8
I have a 1990 Chevy motor home w/7.4L eng. The problem is when it starts it will run for about 10 secs them shuts down. I have replaced fuel filter, regulator,map sensor. This started when the oil pressure switch came apart. I replaced it but the problem is still there. Do you have any suggestions?
Sep 6, 2010 at 10:50 AM
MIKE H R
  • 3,094 POSTS
could you explain to me when you say the oil pressure switch came apart? I am thinking that that the computer is picking up a false signal. You cand try to reprogram the computer by taking it in and have it professionall;y reprogramed or you can try to disconnect the battery circuit and leave it off for as couple minutes then reconnecting. This way when you start it will pick up correct codes. The oil pressure switch may be not sending a signal to the engine that you are not getting oil pressure and shutting down the engine. Check the connections on the switch to make sure they are clean and dry.
Sep 18, 2010 at 8:01 AM
