1985 Other Chevrolet Models turns over but wont start
LIZAT26
  • 1985 CHEVROLET
Engine problem
1985 Other Chevrolet Models V8 Wheel Drive Type unknown Automatic 16500 miles
I need help my truck ran fine I got to the store and came back out and my truck wouldn't start it turned over but thats it
Saturday, January 26th, 2008 AT 3:00 AM
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Saturday, January 26th, 2008 AT 6:40 AM
