1984 Other Chevrolet Models Fuel injectors not working
1984 CHEVROLET
67,000 MILES • V8 • 2WD • AUTOMATIC
LBCTWKEN
I have replaced the fuel pump and filters but no fuel comming out of injectors. I checked they have power going to them and fuel but wont spray. I have also changed the computer and the injectors and still not working. What could it be?
Dec 5, 2008 at 12:13 AM
JAMES W.
  • 2,394 POSTS
Your fuel injectors are feed with a constant 12 volts all the time with key "on". The ECM grounds the injector coil to make it fire. You can test injector pulse with a test light, but the best way is with a unit called a "noid light". These create a quick flash much the same as the bulb in an ignition timing light. Assuming you have good spark, injector pulse is what I'd check next. Please advise>
Dec 5, 2008 at 4:09 AM
