1981 Other Chevrolet Models Transmission
1981 CHEVROLET
HOOKSHOT
Transmission problem
1981 Other Chevrolet Models V8 Two Wheel Drive Automatic
I was just getting on the interstate I started to get up to speed then had to hit my breaks really hard to avoid getting in an accident. After that the trasmission wouldn't shift passed 2nd gear what could be the cause of the problem or fix. The engine is a 350 V-8 the transmission was bought by magdog transmissions in Florida and was a rebuilt transmission a few years ago the truck sat about 2 years and was only driven on for 500 miles.
Jun 6, 2010 at 9:28 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
it's best on a case like this to have atrans pro look at it. this could either be a thm200 or thm 350. Both of them operate a little differently. It could be a stuck valve or when you hit the brakes hard the pump sucked a little air and froze up something in the trans. You may get lucky and when it cools down it may start to operate correctly as well.
Jun 7, 2010 at 6:55 PM
