1977 Other Chevrolet Models Engine will not operate at highw
1977 CHEVROLET
60,000 MILES • 6 CYL • 2WD • MANUAL
MARGIEE2001
I have a 1977 Chevy PU 250, 6 cylender that will not come up to highway RPM. Now if I choke the engine it will come up to highway speeds and as soon as I let the choke off the engine will die. It idles, but it seems a little rough. Enough gas seems to be getting to the carburator, because it will run as long as I hold the manual choke partially closed.
Aug 10, 2009 at 2:29 AM
HMAC300
  • 48,601 POSTS
It really sounds like you have a bad vacuum leak. If you have a guage available, hook it up to the engine and take a reading. You could also have a plugged cnoverter or collapsed exaust prior to the converter. A vacuum guage will show this as well with a low reading.
Sep 9, 2009 at 6:47 AM
