1973 Chevy Nova tumbler
KRYSTALEARNINGCARS
Steering problem
1973 Chevy Nova V8 Two Wheel Drive Automatic
i was wondering how to get the tumbler out of a nova.
i can't seem to figure it out.
Aug 15, 2009 at 3:37 PM
HMAC300
  • 48,601 POSTS
If this is a column mounted switch, there should be a small hole in it. Install the key then turn it to accessorie. While doing that stick a paperclip in it to push the button inand remove the tumbler. If you don't have the key for it and are replacing the tumbler, then get a slide hammer with a small screw on it, screw into the tumbler and use teh slide hammer to pull itout. Then install the new tumbler by llining up correctly and turn to start to install.
Sep 15, 2009 at 12:38 PM
