1967 Chevy Nova neutral safety switch
1967 CHEVROLET NOVA
100,000 MILES • V8 • 2WD • AUTOMATIC
ACADIANMAN67
I'm going crazy with my 67 Nova. I have a no start issue. I have installed a new starter, new ignition switch, and now a new neutral safety switch and still it will not start. I will start if i by-pass the ignition and use a remote start button from outside. The battery is slightly low from sitting but it can't be the issue because when I remote start it, it cranks right up.
Any ideas what the issue is?
Sep 19, 2009 at 8:08 AM
Best check the NSS positioning-from the ignition switch start position is goes thru the NSS and then to the starter solenoid
Sep 19, 2009 at 8:17 AM
ACADIANMAN67
What's the best way of checking that NSS position from the ignition switch?
Sep 19, 2009 at 8:53 AM
Disconnect the NSS have helper hold key at start cranking position should have power at 2 wires for park and neutral contact
Sep 19, 2009 at 7:55 PM
