studdering 3.1
CHEVROLET MONTE CARLO
DGILLIS1234
I'm a backyard mechanic and I'm tring to find out what's going on so here it is= car in studdering and no power, changed all plugs (nasty white powder on all but #1 cylinder looked normal owner told me he has been using gas from his work and they have had problems with water in the fuel, put new gas in) and wires and vacuum line going into intake, it runs better now but still studdering I checked all the plugs again, they look good, checked coil OK fuel fliter changed,egr
Nov 22, 2007 at 10:02 PM
TOBYU
  • 89 POSTS
Get an ohm meter and ohm out all the spark plug wires from end to end..
I like them to be less than 12K ohms. You might find a coulple that show no connection at all from end to end....problem.
Nov 24, 2007 at 7:46 PM
