Hi thank you for the donation your trouble codes are a direct result of the water however drying time may or may not fix the problem depending on how long
these areas was exposed (two hours). The oxygen and possibly the pcm I would let it sit a few more days if that doesn't help then you will need need to address the two individually, by replacing them. Sorry to be the bearer of bad news
SPONSORED LINKS
Friday, May 14th, 2010 AT 7:09 PM
