2004 Chevy Monte Carlo Speedometer
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
KELLER44
Recently my speedometer has gone completely out of whack. Its has reached over 120 when I'm going about 30, and at that time when I stopped it would go down to about 70. Right now its parked and stopped at about 50. Not sure if this is a fuse problem, cluster problem or what it might be.
Jan 30, 2009 at 8:07 AM
DOCFIXIT
  • 18,828 POSTS
Check engine light on? Any problem trans shifting? If no to both then speedo head problem.
Jan 30, 2009 at 8:10 AM
KELLER44
no to both, also noticed that the background lights to the speedometer and the others to not be working, but the lights that show me if i'm in drive or park are working fine
Jan 30, 2009 at 11:39 AM
MYKJAK
I had the same problem a year ago. The entire instrument cluster had to be replaced
Jan 31, 2009 at 7:12 AM
COASTER2U
It is your cluster, the gears in them are cheap and they break....you can buy a new one from the dealer-($$ expensive)or remove the old one and get it repaired which is much cheaper
I am in the same boat as we speak and am trying to find out how to remove the cluster if anyone happens to know??
Jun 20, 2009 at 9:27 AM
COASTER2U
thanks for the reply, but I have found a repair place in Canada at the same price
Jul 28, 2009 at 10:44 PM
