the drivers side heated seat does not get hot . the light comes on to let you know that it is on but it does not get hot
Dec 12, 2008 at 1:53 PM
MIKE H R
MEMBER
check the connections unde the seat, to make sure they are getting a good connection. you can also check to see if you are getting power to it by using a tester. Disconnect the plug under the seat and check to see if you have power to it. if the other seat gets hot then you have power from the fuses.
