2000 Chevy Monte Carlo steering or alignment
WASP1061
  • 2000 CHEVROLET MONTE CARLO
Shakes or Wobbles problem
2000 Chevy Monte Carlo 6 cyl Automatic 151000 miles
my 2000 monte carlo steering shakes, I'm not sure if the alignment is off due to the recent massive pot hole problem in Chicago or if I have a problem with one of my front tires. What would cause the steering wheel to shake?
Sunday, May 24th, 2009 AT 10:58 AM
  • 110,053 POSTS
If it shakes all of the time, chances are it's out of alignment from the pot hole, or a steering component was damaged when you hit the hole. If it only happens when you used the brakes, chances are you have a warped brake rotor.
Wednesday, June 10th, 2009 AT 1:24 PM
