Hello, is the vehicle running? Can you check for codes? Some of the national brand autostores will check codes for free.
If it cranks good but won't start, you can have a helper crank it, while you check for spark at the plugs and fuel pressure. My first thought always goes to the rpm signal, but, you never know.
SPONSORED LINKS
Friday, March 6th, 2009 AT 12:33 PM
